ISPs, color shift and other questions
  • Since the discussion on another thread about colour shift I have started looking at the more recent ISP panels instead of PVA as colour shift seems to be not uncommon there. I have abandonded the idea of two monitors for one big one and have been reading about the NEC LCD2690WUXi. I was particularly attracted by the "ColorComp" feature. The results in the test on brightness look impressive.
    The NEC website describes this as a H-IPS A-TW panel and your site as a AS-ISP panel. Could you first please explain what these terms mean.
    The only part of the review that causes me any concern is
    "The crystal effect for which this panel type is known is still present in the H-IPS panel on the LCD2690WUXi, but it is much fainter than in older-style IPS-Panels." I have no opportunity to look at any ISP panels so I do not know what this looks like. Is it possible to descibe it?
    I regard color uniformity over a large area as very high on my list of priorities, I don't play games and probably will not use it for watching DVDs. It is for work applications, which is mostly software development with some office applications and a bit of graphics. Color is important to me and I spend most of my life looking at the screen, and I'm just fussy. Do you think this a good buy for my requirements or is there something else I should look at first? I cannot afford more.
    Dani
    Dani
    Hey,
    both of those designations mean relatively the same thing: "advanced" IPS technology with wider color gamut. I believe the names are proprietary and I don't think there's any real [quality] difference between the two.
    The LD2690WUXi was definately on my short list a while back but I needed a jack of all trades, leaning towards digital imaging work, but still capable of casual gaming or DVD viewing, etc.
    I think I've accomplished that with my S2231W but considering your very specific needs, the LD2690 should certainly be at the very, very top of your list :D
    With all due respect to the keen PRAD members and staff that are doing their best to support their English forums too, you will have all the info you need, good and bad, over at [H]ard|Forum and their excellent LD2690WUXi thread.
    Good luck and let us know what you end up going for :)
    Traveller - Geneve * Melbourne * Miami * Wien
    I: E6850/ P5B-D/ 2GB DDR2-800/nV 8800GT-512MB/ XP+nV169.28
    II: P4 24b/ P4PE/ 1GB DDR400/ nV6800GT-128MB/ XP+nV169.21
  • I am bit confused, traveller.
    Here you say the NEC LCD2690WUXi would be a good option for me as I want good colour accuracy and especially uniformity, but I only sometimes use colour managed software but most of my work does not. On the thread about the Eizo S2231W I responded to your post about wide gamut monitors (which was also not strickly about Eizo S2231W as your quote was about a Dell 2407 HC display) you advise against it because it is wide-gamut. This monitor would seem to have better colour unifirmity across the screen but I don't need an extended colour range so I was looking for a way of using a profile when with colour managed software but have reasonable colour when not.
    Dani
    Dani
    ...you advise against it because it is wide-gamut. This monitor would seem to have better colour unifirmity across the screen but I don't need an extended colour range...
    Well, it wasn't my intention to confuse you but I got confused myself. However, your statement above clarifies things (I hope).
    You want a monitor that can accurately render colors defined by the sRGB colorspace without depending on color-aware applications.
    When I calibrate a monitor, it creates a color profile that applications like Photoshop use, but also loads a "profile" directly into the Graphic card's LUT (color lookup table). So, I believe that it should be possible to benefit from a calibrated monitor even without the use of color-aware applications.
    BUT, this theory of mine only applies to non wide-gamut monitors... . So, just like I mentioned in the other thread, you don't want a wide-gamut monitor. Such a monitor does not necessairly bring you "better color uniformity", it only brings you different colors... .
    Last but not least, don't bother looking for a prefectly factory-calibrated monitor because it probably doesn't exist. some monitors fare better during a review right out of the factory then others, but that's still not a guarantee that your unit will have the same exact "out of the box" accuaracy.
    p.s. Don't confuse IPS LCD technology with wide-gamut. My original post above was to reinforce IPS as the correct technology for your needs, not the fact that the LCD2690 has wide-gamut capability...!
    2 Mal editiert, zuletzt von traveller ()
  • Thanks for replying, Traveller. It did help to improve my understanding. :)
    If I have got this right with a standard gamut monitor a calibration profile can be used in either the managed (aRGB) or the unmanaged (sRGB) colour spaces but for wide-gamut monitors it can only be used in the managed space so I should not get a wide-gamut monitor.
    Most of the better bigger monitors seem to be wide-gamut so I think it is back to 2x 19" or 21" .
    I agree that the factory settings are not to be relied on so I do want one that I can calibrate and I want the ISP panal. Just a coupe of questions if you don't mind. Is S-ISP standard-gamut? and do I need to make sure it has LUT?
    Dani
    Dani
  • Dear Dani50,
    according to my info the Eizo S2431 (24") has:
    * also S-PVA panel
    * no color shift problem like the S2231
    * no wide gammut
    * price of y-shaped grey version (at least here) is only around +€150
    I have ordered the Eizo S2431WH-GY and hope to get it next Tuesday.
    Is S-ISP standard-gamut? and do I need to make sure it has LUT?Dani
    A wide-gamut monitor uses special CCFL lamps or LED backlighting technology. There is no change in the actual Liquid Crystal technology (afaik), directly related to gamut and only contrast and/or viewing angles, etc. The trademarks "H-IPS" and "AS-IPS" etc. represent the combination of IPS and wide-gamut backlighting.
    Having said that, it may very well be that some manufacturer will offer an S-IPS panel with wide-gamut backlighting, so make sure to read the full specs of the monitor(s) you are interested in.
    Btw, maybe you should have a look at the following sites for a little more in-depth background on the variuous LCD tehnologies on the market today:
    LCD Resource and the "originating" thread over at AnandTech's
    TFT Central (UK)
    Last but not least, I consider Xbit Labs as one of the better sites reviewing Display Technology along with PRAD and BEHardware.
    p.s. I'm fairly certain that all monitors have an internal LUT, just that it is 8-bit (or even 6-bit for certain cheaper TN panels...) and I cannot honestly answer your question as my own knowledge of the benefits of 10, 12-bit "internal" processing is still unclear to me...
    EDIT: Here's a very good (but unverified) summary of the backlight's role in Gamut from the LCD Resource Thread (new version):
    "...the range of colors an LCD can display is directly dependent on how pure the color components are. Typical backlights produce a white that yields 72% coverage of the NTSC color space standard. Newer backlights use different phosphors that can effectively cover 92-97% of the NTSC space. LED backlights, which are not yet very common in LCDs, can cover up to 114% of the same color space."
