Hi ![]()
First of all I want to apologize for my English.
As you can see on the pictures below (under links), there are some backlight (?) issues on my new monitor. The first 3 shots are made with plain white, grey and black pictures displayed on the screen. There is noticeable “dirt” under the top edge of the monitor on the second image (should be grey). This issue is much more noticeable in the last image (there is an empty movie frame displayed). When using this monitor for just web surfing or with colorful, bright scenes, there is no problem. But when I want to play some “dark” game, for example Deus Ex or Thief, the part of the scene which is rendered on the top of the screen is completely dark or negative like.
Should I send this monitor for warranty or this is common issue on the LCD`s?
This is my first LCD and I’m very unsatisfied :(.
Every shots where made with monitor set to default sRGB (6500K; 100% brightness; 50% contrast; 2,2 gamma) profile with FinePix E500 compact camera set to "auto".
White
Grey
Black
Pattern1
Pattern2
Eempty frame
Thanks for all advices.
Artur
