LG w2600hp resolution problem
  • I got this display yesterday and i am using it on dvi. the problem is the only resolutions in 16:10 that i have are 1920x1200 and 1680x1050. I can't use 1280x800 or similar. Nor 1440x900. Why ? Is it a limitation of DVI?
    Also this problem is only in windows xp in windows vista its fine.
  • hard to say from here without more specifics. If the desired resolutions are not available under "control panel -> display" then try ATI control panel or the nvidia equivalent, depending on the graphics card you are using. There should be more options.
    Also, did the LG display come with a cd? Or maybe there is a .inf file on LG's website that you can use.
